I600 backhoe
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 backhoe
    Posted: 3 hours 25 minutes ago at 4:25am
Guys I’m having trouble with the steering on my I600. I’m removing the steering cylinder for a rebuild. If that gets the steering working I’d like to remove the hoe. What do I do with the hoses that run the hoe? I believe there are 3.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 15 minutes ago at 4:35am
u going to devoice the hoe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 50 minutes ago at 5:00am
Probably. The rotary swing motor is leaking. A couple other cylinders are leaking. Needs a few hoses. This hoe is big and makes the tractor hard to maneuver here in the hills. I could get a lot more use out of the tractor without it.
This page was generated in 0.057 seconds.
