I600 backhoe |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: I600 backhoePosted: 10 Feb 2022 at 6:37am |
I find out Saturday if I get the backhoe.
I need to get it running where it sits if at all possible. It was running not long ago. Been sitting less than a year. Muffler covered. Gas doesn’t smell sour. I need to know if it’s pos or negative ground or how to tell. I’ll have to bring a battery. I believe I saw an alternator but wouldn’t swear to it. |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 10 Feb 2022 at 8:23am |
If the battery posts are round, they are each different size, not easy to get wrong.
Jim.ME
Posted: 10 Feb 2022 at 9:15am |
As Dusty MI posted, battery posts are different sizes so the cables should only fit good one way. Also, if it is an alternator, it is most likely negative ground. There are positive ground alternators, more a less a special order, but most people just use the common negative ground ones when they do a conversion.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55281 |
Posted: 10 Feb 2022 at 6:16pm |
Just follow the ground up to the battery, batteries are marked. If you have to put a battery on(doesn't have one), and you end up spreading one of the terminals, you are hooking it up wrong...
