I thought of the anti bio fuel nuts today
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 4:45pm
Originally posted by victoryallis victoryallis wrote:
JW
The anti bio fuel folks blow my mind. Why would you be against something uses commodities and in turn helps prices because you can’t maintain your system.   Every bushel that gets consumed is a good thing.
Well I thought about the "give up your soul for a buck" pro bio crap fuel control freaks too. You can keep it and quit promoting that to me and others who want none of it. It is sh!t fuel period.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 4:59pm
No Lonn, that’s a methane digester you’re thinking of.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 5:04pm
So people are trying to claim all the btu’s it takes to plant corn, the tilling, fertilizer, harvest, haul the corn, the btu’s to dry the corn, then store it, then eventually re-hydrate it, then the btu’s to heat it to ferment it, process it, the btu’s to haul the ethanol to fuel terminals where its blended with gasoline, that takes less btu’s than drilling and refining crude oil?
Edited by Lars(wi) - 16 Jul 2021 at 6:45pm
AC/DC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC/DC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 6:40pm
My diabetic friend told me he can't eat too much corn because of the starch in it, which turns into sugar. So,personally, I don't put it in anything if I can help it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:11pm
Lonn... i hate it when you beat around the bush... tell me what YOU REALLY THINK !!LOL
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2021 at 8:25pm
I guess when I get p!ssed off I get p!ssed off and, as someone once told me, it's better to be p!ssed off than p!ssed on. Wink
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 6:53am
I don't know, I rebuild an awful lot of Carburetors for customer's, and I can tell ya first hand that since Ethenol has been around, the insides of the these Carburetor's whether they've been sitting or in service always have muck in them from the ethenol fuel. It definitely wasn't like that back in the 60's and 70's when I was rebuilding Carburetor's back then. At least around in these parts. My own experience with my small engines running ethenol in them whether its mixed for the 2 strokers or GT's, never had stuck valves, gummed up carbs and muck in the tanks like recent years. For the 2 stroke equipment that I have like the leaf blower, weed wacker, etc, I've been running the 50.1 premix fuel you buy at the box stores, and after a couple tank fulls of that run through that equipment, those engines rip now. No ethenol in that fuel and 93 octane. The GT's I add some Seafoam in the tanks to keep the valves from sticking. I guess some of you guys are just lucky you don't have the problems like some of us other dudes. I'm not sure about the humidity factor either, but ethenol doesn't work round' here for me...
Steve@B&B
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 3:33pm
I run standard 87 octane up to 10% ethanol gas in pretty much everything. I can let the tractors sit for 6 months (winter) and fire them up with a fresh battery charge in spring no worries. I just store them with Sta-Bil and sometimes Seafoam, and it's worked for years.
The only things I get ethanol free for are:
1) My STIHL chainsaw
2) My Snowblower
And I just buy 89 or 90 octane, whatever I can find for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 5:48pm
Steve@B&B
At last some experience and knowledge...  I have been running camp stove fuel and premix in all 2 stroke, and straight in infrequently used 4 stroke equipment, for years, now.  $9/gallon vs $6/qt, for the premix stuff.  If you can find Naptha, its the same as camp stove fuel, but around here, its at least $5/gallon more than camp stove fuel.
Buying the more expensive fuel is cheaper than rebuilding/replacing carbs, on this small equipment!
The difference between me and the OP is that I didn't call him a nut, just because he doesn't agree with me...Wink
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 8:32pm
I do believe that the humidity in different areas affect the fuel of today.
I run ethanol fuel In every gas burner I have without problems, except for my 4 wheeler ATV, if I run ethanol In It I will be pulling carb and cleaning it every 6 months , it really gums it up.
I can’t explain why my tractors and vehicles tolerate the ethanol, but my 4 wheeler just won’t run it. I buy 100% gas for it now and don’t have to worry about cleaning the carb.
I also have Stihl chainsaws and they seem to run fine on ethanol. Just mentioned because someone else mentioned stihl saws, maybe that humidity thing again.
But ethanol will plug my ATV carb up so bad it’s super hard to clean it all out and get it to run.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:16pm
I’m going to point out a few things. I have exclusively ran E10 in my CA for over 20 years now that I’ve owned it and almost as long in my Oliver 60. I have not had any carburetor problems on either tractor in all of that time. Ever since I got my D17D, it takes a year to burn a full tank in either of them. I do put Stabil in them.
I have no doubt that some of the carburetor guys are seeing heavy deposits in carburetors, but I will bet my next paycheck that those carburetors sat YEARS to get that way without use. Those black deposits are what’s left when the volatile compounds are allowed to evaporate. Today’s gasoline and diesel are much more volatile on purpose to aid in atomization and cleaner combustion. Does alcohol attract water? Sure it does. When I need to verify alcohol content in gasoline that’s how I measure it, with water. It’s also one more reason for leaving the sediment bowl in place. A full fuel tank has far less moisture in it than a full one. That’s why the owners manual says fill the tank when you’re done to push out humid air to reduce condensation.
I do get a chuckle out of the guys who say alcohol in fuel is the devil’s handiwork and in the next breath say Sea Foam is the greatest thing going. Sea Foam’s active ingredient is ALCOHOL combined with some light machine oil.
My point is if you run your gasoline engine regularly, you can use E10 with no ill effects. If you don’t run them often, a preservative such as Stabil when used according to the label is very effective at preventing problems from stale fuel.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:24pm
So one of my brothers has been running non ethanol in his D17 for years now. My cousin and I borrowed it ao rake hay in a field we share and I told cousin don't put gas in it. That it had more than enough gas in it for what we need it for. So he ends up putting gas in anyhow and it's that crap gas and so, since I was somewhat responsible for not making darn sure it had only good gas, I ended up draining it all a month and a half later including the carb. The plug in the carb already had a brown coating on it. It ran fine and started right up but it had that same crap I find in all carbs and fuel tanks using ethanol. Now I have to find a quick way to clean the fuel tank from that brown crud.
Wink
I am a Russian Bot
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:45pm
Talking to a few people involved in fuel transport, they say that there is water "slugs" used to clear pipelines when they switch product, so there is alot of water in fuel period.
Myself, I understand the potential downfalls of biofuels, but when faced with the option of biofuels in an unmodified Allis Chalmers versus crushing said Allis for scrap and being forced to buy a Electric tractor to "go green" I'd rather use biofuels as a negotiating tool against the rabid environmentalists and keep my old junk.
Myself and my personal experience, an old lawn tractor stored outside 365 days a year and rarely ran is the only thing I have trouble with, and I mostly blame my storage method. Old trucks that sit like an old winch truck and a grain truck I have had a little trouble with ethanol, but you guessed it, stored outside as well.
Stored under a roof will solve most problems IMO.
As far as diesel, I have never had biodiesel problems. In fact, I actively search it out, my old GM 6.5Ls run so much smoother with it, and I run Stanadyne Lubricity formula every tank, and most have had new Bosch injectors after I bought them, so IMO the smoothness of the B20 has to mean its burning completely and clean to get it to idle like it does. running "rougher" (still smooth, but not as smooth) on regular diesel cant be blamed on stuff like worn injectors, because at the time of the roadtrip they had less than 5K miles on them.
So perfect fuel? No,but neither is modern diesel after 07 change from LSD to ULSD.
Only option we have to calm down the environazis? IMO, yes.
End of the world junk? Far from it.
People that have terrible maintenance, or refuse to acknowledge their fuel handling and storage techniques might be deserving of blame, usually complain the loudest against biofuels. (guys so cheap they dump out dirty fuel filters and screw them back on, etc.)
Embrace a little compromise and keep a seat at the table, or get kicked off the table and get told what to do by the remainder is what I see happening. We need to get our biofuels industry to talk up all the carbon sequestration and other "green" talking points that biofuels have to keep the current administration happy, and our old Allis' will live on.
As far as the OP, a little less hornets nest wacking would probably get a friendlier response... ;)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:49pm
I cant speak for the efficiencies in the corn belt, but here in the dry High Plains our grain almost never has to be dried (you have to hurry with harvest to keep corn above 10 percent...) and there are many cattle feedyards within a close radius, so the distillers grain is usually hauled wet direct to the feedyard.
Cows drink less water when consuming the WDG, so IMO that should be a factor as well.
So in regards to our local ethanol plant, I'd say it is quite efficient.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:51pm
All my tractors and lawn mowers are stored inside almost 100% of the year except when in use.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 10:57pm
Capitulate? No thanks. And I have never reused any filter before and have all my maintenance records including oil changes recorded in a book for the past 10 years. I'm pretty fussy on maintenance.
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 5:54am
Maybe the best compromise would be to mandate all those  growers that want to sell their products to make ethanol and bio diesel be required to use 100% bio diesel or E85 to
in their tractors and trucks to grow and transport those crops.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 6:11am
'Gasahol' came to our town in the late 70's and was available at the co-op feed mill/farm store. I needed fuel for the WD to make it home with a load of feed in the auger wagon because I didn't fill up at the on farm tank kept full by Amoco distributor. On the way home sheets of brown varnish were floating around and clogging things up.  That day I learned how to get the clogs worked though by manipulating mixture screws, sediment bowl shut off valve, and choke plate. Made it home but manipulated on it several times over the next few weeks but I don't think the carb has ever been off the engine. Runs without trouble or manipulation today.
I switched to the pre-packaged two cycle gas because I use so little and a gallon of home mixed would be  ok when new - but after a few months sitting, engines just would not run well unless I dumped the old made new and worked new fuel into the system.
This page was generated in 0.093 seconds.
