I need the procedure for installing a garden tille
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: I need the procedure for installing a garden tille
    Posted: 29 Mar 2017 at 4:56pm
Need the procedure for putting a garden tiller on a 6:16 / 6:20 / 7:20.   More specifically when should the PTO be able to be hooked up before the top link or after
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 9:27pm
I connect the 2 lift arms first, pto next, and then the top link. I put Never Seize on the pto shaft to make it easier to install and remove to pto shaft. Grease tends to be thrown due to the hi pto speed that's why I use the Never Seize.
This page was generated in 0.162 seconds.
