I need D15 II clutch help
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: I need D15 II clutch help
    Posted: 05 Jul 2011 at 9:16am
I need to know specs for the step on the D15 II flywheel. I am having it machined and need to know the difference from the outer bolt on area to the inner surface where the clutch works. Thanks y'all! Dana
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 9:27am
The machine shop I use {NAPA} has the specs in their flywheel books.
If you shop doesn't have the specs they will measure from a spot on the flywheel that is not worn and adjust the lip to the new depth of the flywheel surface.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 12:26pm
Het Jeff thanks. My guy doesn't have the lip specs so I am trying to find them. OK gotta go bale bout 6 loads!
