I need a 170 AC governor housing from 226
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: I need a 170 AC governor housing from 226
    Posted: 25 Jan 2010 at 1:29pm
I am looking for a governor housing from a 226 gas AC 170 , the one off my 1959 model 226 wont work, the dowl pin does not line up, from the block to the housing. Unless someone knows a way that i can still use the one I have now? I can get the year of the engine fromthe serial to be more specific. thnaks
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 1:31pm
I believe the 170  gas with 226  were produced from 1968 to 73 ?
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2010 at 2:24pm
Can you post a picture of what you need? As far as I know the Housing is the same mounting patern from the wc through the 175 including the E combine. there were different variations of the housing with the oil fill outlet but I thought the way they mounted was the same?
Matt
This page was generated in 0.041 seconds.
