I have proof |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: I have proofPosted: 21 Mar 2023 at 7:48pm |
That Joe was here today. We finally got to spend a little time together.
Not only that but I got to speak with Shameless on the phone as well. Feeling blessed tonight. Look at this beauty resting comfortably in her spot. ![]()
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34624 |
Posted: 21 Mar 2023 at 8:44pm |
Yes, Blessed you are. ![]() Nice vice you have there...for that fact, nice set-up. Bridgeport type mill and a lathe. A person can do a lot with them if they have the skills. Is that all the insulation you need in the walls there? Sure wouldn't keep the 40 below winter out here. |
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 21 Mar 2023 at 9:19pm |
looks like you got a LIGHT on the mill !! .... How did the 3 phase work out ?
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 21 Mar 2023 at 11:07pm |
Lookin' good, Thad, great setup, but I think I may hafta bring you a larger lathe... Sooner or later, 'yer gonna need to swing something bigger, and longer... ![]() Mebbie you should have a Steptoe shaper, too... |
Thad in AR.
Posted: 22 Mar 2023 at 4:23am |
Thank you JC. It definately needs insulation. It was originally built as a pole barn to keep my tractors dry. I’m slowly getting to the insulation. I’m adding stud walls between each post and using bats on the walls. Hoping to win the power all and spray foam the lid. |
Thad in AR.
Posted: 22 Mar 2023 at 4:29am |
Steve it worked out very easy. Once you and I discovered the light had its own power source. I ran a separate power for the light and hooked up the rotary phase converter my self. It was actually fairly easy. The big switch on the columns is strictly foreword or reverse. The switch on the head turns the main motor on in high range and low range. It runs which way the reverser switch designates. The small switch on the columns is the power feed on and off/foreword and reverse. The mull must be running for the power feed to run. |
Thad in AR.
Posted: 22 Mar 2023 at 4:33am |
Yes Dave I’ve already had a few times the lathe wasn’t big enough to turn what I needed. I may sell this one and upgrade at some point. Thank you for all the help along the way. |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 22 Mar 2023 at 9:07am |
Sounds great all the way around.
shameless dude
Posted: 22 Mar 2023 at 11:08pm |
was nice chatting with you too Thad! did he ever come back for his phone? prolly to busy with miss big ****s??? lol
Thad in AR.
Posted: 23 Mar 2023 at 4:50am |
I had to take it to him cause he was busy.
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5181 |
Posted: 23 Mar 2023 at 5:37am |
Can't really think of a better reason to leave it myself
