I got the WD!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 11:23am
Jacob, sounds like you are well into the adventure involved in digging into a 60+ year-old tractor! The good news is that all of those things are probably repairable, given a liberal application of time and money! As to your engine oil capacity question.....sounds like it's now overfilled - I'd be careful to not run it that way too much. I don't own a WD, but my friend does - will ask him to measure the length of the stick for you. The dipstick should not be running into any moving parts when inserted.
WC, CA, D14, WD45
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 12:29pm
Oh yes, there is always sometihing else to fix... LOL!  I enjoy it thouugh, its a fun hobby, and when it becomes unfun, you can just walk away for a while and work on something else...
As for the engine oil, that is what I thought about being over filled, but where is it going if the dipstick is still not "full"?  I'm puzzled.  Thank's for getting the measurment, I appreciate it!  Mabey that will solve the mystery....
Anyone have any ideas what it could be hitting when inserted?  You can feel the dipstick vibrate like its end is just rubbing on something rotating in the engine while inserting, but it stops once all the way in.  Am I crazy?  Mabey the dipstick should have a bend in it, and it dosent?  Thinking out loud here....  Should the dipstick be strait like a C dipstick?
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 2:03pm
Check it after the oil has all flowed back into the pan.  It sounds like you ran it and checked it right away-the engine could be holding up to a quart I would think.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 2:46pm
Jacob, I measured the dipstick in my friend's WD. It's 9.5" from tip to the ring that seals against the dipstick hole. And it's straight - no bends. I'd let the oil run down and check it again if the dipstick "measures up". LOL
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 3:37pm
Ok,
So I just called Dad, which just happened to be in the woods with the tractor.  He did some checking for me.
The dipstick checks out.  Its 9.5 inches like it should be, and not bent.
Dad says the oil level (now that it has been siting since Thanksgiving) is "right where it should be" in between the high and low marks.
So that answers part of the mystery, the oil just must have not all drained back to the bottom when I chacked it.
And the only thing we can think of is that we inadvertenly bought a one gallon, and one quart jug of oil originally, as opposed to the 5 quart jug and one quart jug I THOUGHT I got.  Then added another quart once I seen I was still low.  But I'm almost positive I got the 5 quart jug.
Dad's going to check the jugs once he gets home (which we put the used oil in for recycling) But he put some out this week for recycling, so we might not know that way.....
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 4:04pm
Ok,
So I've been doing some detective work.  I found the recept for when I got oil. (I know, you're not supposed to keep records of expences, right, LOL!)
It clearly shows that I got both the 5 quart jug and one quart like I thought I got.  Then the next day I got the additional one quart since I knew it was low.
That adds up to 7 quarts the last time I checked.
Where did the extra quart go?  The dipstick shows it's perfect oil level now.  There is no obvious sign of oil leaks, and if there was one big enough to loose the original one quart immeditaly after I filled it up (or even after it all drained back to the bottom of the engine), you would think we would have noticed that, right? LOL!  And if that was the case, the engine would be drained empty by now....
Is there any chance oil pans could have been changed from a tractor with a bigger sump?  I'm scraping for possibilities here....
What am I missing?  Show me why I'm stupid guys!
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 4:32pm
Your dipstick is very likely touching the crank when you're pulling it out with the engine running. If it doesn't rub when it's fully inserted, I wouldn't worry about it.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 4:58pm
most of the time the if the dip stick is hitting the crankshaft the dipstick will come up out of the engine.  also in welding cups on the oil pans  for my stoker crankshafts I have found that it takes ten quarts to get up to where the cork oil pan to main gaskets go. so i dont think seven quarts would hurt anyting . it would blow out the rear rope seal if over filled extremely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:06pm
You may find gaskets won't do the trick on the exhaust. I put a new manifold on my 45 because the top was messed up and new gaskets didn't last a month. I then pulled the head and milled it, recutt the manifold, and put new gaskets in and it hasn't leaked in several years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:16pm
Hopefully that isin't the case.  I guess I'll cross that bridge when I get there.  When the day comes to pull the manifold and I can check things over closer, I'll post an update.  Thanks for the heads up though!
Where did you get your gaskets?
Jacob Swanson
