I am getting power steering fluid in dist points,
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: I am getting power steering fluid in dist points,
    Posted: 04 May 2010 at 6:57pm
D17 gas 226 , i am getting power steering fluid, I actually use auto transmission fluid in ps, in the distrubutor where the points and condenser etc. , are located I dont know what the problem is and not sure how to fix. The tractor stalled on me this morning and when I took of rotor cap and cover there was a good amount of oil in the dist chamber, is there a seal or gasket that can be replaced or what I was thinking is that the breather is plugged on the ps to create pressure I dont know. If any one knows please let me know what you think . thanks,
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 10:09pm
There is a seal at the rear of the pump that sounds like is leaking
Dean Ag 800-589-2426
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 5:19am
Albert is right...the seal in the pump is leaking and needs to be replaced.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 6:17am
The seal is leaking and possibly the needle bearing inside the pump are also worn/worn  out. Why don't you change the oil and get rid of that %$#@ water like transmission fluid and use universal modern hydraulic fluid which is thicker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 7:12am
I can use reg hydraulic fluid in the power steering? ok I will drain the auto transmission fluid ( it really is thin stuff I agree) and replace, albert I will call you today you maybe have the part I need? thanks all.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 10:14am
Or you can just take the whole ps setup off and give it to me!
(my birthday is coming soon, not many shopping days left...)
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 11:47am
DR, I'm glad I saw this post. Am I correct in thinking that it just works better with hytran in it? Got my pedestal off and fixing leaks/bearings at the moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 4:11pm
Just use the modern day hydraulic oil....everything works better and far fewer leaks.
