Hydrostatic Transmission
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Topic: Hydrostatic Transmission
    Posted: 22 Nov 2009 at 2:18pm
Can anyone point me to an explanation of the working of a hydrostatic transmission as used on small, (garden/yard/lawn), tractors?
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 3:34pm
Here's a link to an online pdf file (takes a while to load)
It explains how it works in Section II
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 7:08pm
  depends on tractor  sunstrand   dana   eaton   an more brands   all are different  to name a few
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 9:51pm
Pump and a motor , pump makes fluid pressure and motor drives, moving swash plate on motor gives speed and reverse. Pump can be piston or rotary, motor is piston type.
 Most have built in relief valves and by pass valves .  Small tractore units are normaly single case with both units within one housing.
 Skid loaders, combines,  swathers or other such would be separate units, a charge pump or case drain keeps units of this type from getting air bound or running without oil.
Eaton, Sunstrand, Vickers, were used on many older units Hydrogear seem to be used on many units now. Can get service manual from them for different models.
 use SAE 20/50 oil in them , others seem to use 10/30 as fluid.
Edited by Coke-in-MN - 22 Nov 2009 at 9:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2009 at 10:24pm
On a hydrostatic trans, they use piston style pumps. The "motor" is of fixed displacement. The pump displacement is variable to make speed infinitely variable. A hydro gear system is different in that the pump and motor are both fixed displacement and a valve is used to control the amount of fluid to the motor. Cub Cadet and John Deere have always used a hydrostat system because at lower speeds they consume less power. Case uses a hydrogear type system. The Case system makes for more hydraulic function capability than all others, but the down fall is more engine power is consumed pumping more fluid at lower speeds means less power available for attachments/more fuel usage. The reason hydrostatic systems are more common is they are more efficient, pumping only the needed oil for the speed selected. A small, low pressure charge pump provides oil to the pump and can provide limited hydraulic lifting functions.
This page was generated in 0.118 seconds.
