Hydro mower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Hydro mower?
    Posted: 30 Sep 2018 at 8:00pm
My Jacobsen mower when going up a hard grade makes a noise. Doesn't do it on the flat, just up a hard grade. Doesn't lose any speed , just a high pitched chirpy noise.Deck is hydro and doesn't lose speed either. What would cause this? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 8:09pm
combines are the same way, it's just working/pulling harder than usual, shouldn't worry about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2018 at 9:51pm
I was wondering what causes the noise and where it comes from? Could it be air in system or restriction? Just wondering. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:27am
the further you push that lever ahead, the more fluid it takes, might be sucking sum air with the fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 6:01am
ONLY going uphill ?? If it doesn't do it going DOWN the same hill, it's probably a little low on oil ,cause it's all at the back of the hydro unit. Hopefully you can check and add oil if needed.
A LOT of JD riders 'self destructed' the hydro units..cause was 'built in' from the factory too !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 8:49am
I replaced filter and checked oil. Didn't stop the whining noise.It has high and low stick, then uses a pedal for direction and speed. Tracy
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 11:40pm
we rebuild quit a few tuff torq trans axles each year if you change the oil right now the noise might go away and it will live a long time and it might allready need to have the pump gone through if this is a tuff torq use 5-50 mobil 1 full synthetic .  john deere , husqvarna and most of the  others brands use this brand of trans axle
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 11:41pm
missed the last post
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 12:41am
Hud...mine ain't making no noise, but what would a Dixon ZTR have for a trans axle? does it say on them anywhere?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 8:06am
My toro Z makes more squawking noise and jerks more each year.
I think it i the sign of things to come.  Confused
BTW, it loves to go down hill and is quiet as a mouse while doing so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 8:51am
This mower only has 625 hours on it. Oil looks clean as new. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 9:10am
the ero turns usesa lot of hydro gear brand componants  if the dixon is a litttle old it may still use the cone clutches
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 11:38pm
naw...it's only 3 years old this year. bought it new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2018 at 4:52am
Might also be belt squeal, as load increases...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2018 at 11:38am
some silly city bot moved to the country, and yesterday he was working under his mower, and somehow it kicked into gear and ran over him, killing him! be careful with your mowers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 10:33am
No belts on this mower. Deck is hydro too. Just wondering what would cause the noise? My AC mowers don't whine at all. My Wheelhorse mowers do whine some. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 5:58pm
Some are just noisier than others, what's the brand, model, just to see Iffn I've heard anything...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 6:18pm
Jacobsen 445G Turfcat, 72 inch cut, 28 hp Ford gas engine. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2018 at 8:16pm
commercail grade mower totaly diffferant stuff , might put a gauge on the pump tee in the line and a flow control in line inthe return to tank and look at the preasures and then tighten down the flow control to bump the preasure up if its low and see what it does  doing that use caution it will heat the oil fast and you dont whant to over presure something but you should be able to figure out if the pump is going down or a drive motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2018 at 9:17pm
Might also take a tour around the mower with a laser thermometer, and see if any one component is putting out more heat, than the others are...Wink
This page was generated in 0.088 seconds.
