hydraulics |
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Topic: hydraulicsPosted: 30 Sep 2020 at 12:42pm |
I'm looking for someone that knows hydraulic controls. I bought a towable back-hoe. It has 4 control handles/levers. Left to Right Boom Swing Boom Up-Down Arm In-Out Bucket roll In-Out Is there something that can be added to slow the swing? Also when I push the boom up it drops some before it goes up. Is this a defect or is there a simple adjustment to fix this. Thanks, Dusty
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 30 Sep 2020 at 1:17pm |
Dusty, check out "color flow valve". But they're pricey. In any case, you need a restriction in the line, adjustable is nice. There are fixed-orifice flow restrictors available too. You'd have to experiment to see what size you need. But it's basically just a coupling that screws in between your hose and the cylinder.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 30 Sep 2020 at 5:58pm |
Surpluscenter.com has adjustable flow restrictors, about $10. You might need 2, if your machine uses a ram(s) instead of a clock motor, to rotate the arm.
What machine are you working on?
![]() Edited by DiyDave - 30 Sep 2020 at 5:58pm |
Adam Stratton
Posted: 30 Sep 2020 at 8:58pm |
There are several different styles available, and obviously different sizes, fittings, flow rates etc. Look on ebay or surpluscenter or Baum hydraulics or your local place for a "hydraulic flow control valve" I personally like the kind with a lever to one side better than the needle valve type, but that varies by application.
shameless dude
Posted: 01 Oct 2020 at 1:41am |
if you bought it used your control levers and boxes might have alot of wear, do your levers wiggle without the hyd's moving anything? sometimes it's just a pin on the bottom of the levers that gets wore. not saying you don't need a restrictor, but i'll bet your controls are wore alot. also try to work them with the engine slowed up a bit, you ussually don't have to run the engine full throttle unless you are constantly moving the arm.
