hydraulic self leveling leak
acd14lwfl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd14lwfl Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic self leveling leak
    Posted: 15 Aug 2017 at 5:29pm
I'm a newbie here.  I have a AC D14 I purchased in the 80's and has served me well for many years.  I only use it for mowing now, and in between mowings it is parked and most of the hydraulic oil leaks out thru the automatic leveling shaft paul under the pump pan housing.  The seal looks to be about an 1.25" with about a 5/8" shaft hole and is pressed (?) into the housing.  My question is, has anyone done this replacement and where can I get a new seal?
Thanks for any help.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2017 at 10:20pm
Your local AGCO dealer should have it or get it out and take to local auto supply. They should be able to match it.    MACK
