Hydraulic question
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic question
    Posted: 01 Oct 2025 at 5:00pm
I have a Royal King 37 hp tractor, with the backhoe attachment. If I don't bleed down the hydraulic system, tractor shut down, cycle all controls in tractor and hoe before I disconnect the hoe from the tractor, then I cannot get the quick disconnects reconnected when I setting up to use the hoe again. In that case, I then need to take cover off of controls and open the system to relieve the pressure. PITA!
my question is there something I can put in line that I can relieve the pressure w/o taking it all apart?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 5:33pm
Have same issue with a 2305 Deere loader attachment, anything functional would be ridiculously expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 7:23pm
Dave, I'm sure you are right, but it sure would be nice to have a manual pressure relief that could be installed in line with the two hoses going to the hoe.
Wait for the Lord;
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 7:29pm
pioneer 9500-4 series couplers connect under preasure
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2025 at 9:13pm
Thanks Hud! Dave was right, not cheap!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 3:16pm
could you put a 3000# valve with a couple 1/4 inch hoses between the supply and return lines as a JUMPER... open the valve and relieve the pressure back to suction side ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 9:45am
Steve, I don't think that would solve the problem completely. It would equalize the pressure between the supply and return on the hoe, but not necessarily between the hoe and the tractor. Most often it is only one line that is pressurized, but on a couple of occasions it is both. I know I am prone to 'forgetfulness', but I am pretty sure I am bleeding them at least most of time, yet, when it comes time to reconnect, I find one or both lines w/some pressure prohibiting me from making the connection. I suspect that as the hoe settles, the weight of the hoe on one or more of the cylinders is causing the issue. I need to discover a way to support the hoe better, I think. I was hoping for a relatively inexpensive solution of an inline pressure relief, but what I have seen so far is beyond my budget.
Wait for the Lord;
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 11:03am
Hmm, so cheap and dirty? Heavy on the dirty? Not much is cheap these days. How about just before the hose tip, put in a tee and a little ball valve on the branch of the tee.   Carry a coffee can with you when you hook up and crack the valve into the coffee can. If you can keep it clean dump it into your oil supply. If not pour it on moving parts. Not elegant but beats slamming the hose tip onto the drawbar and spraying oil everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 2:26pm
Hmm, so cheap and dirty? Heavy on the dirty? Not much is cheap these days. How about just before the hose tip, put in a tee and a little ball valve on the branch of the tee.   Carry a coffee can with you when you hook up and crack the valve into the coffee can. If you can keep it clean dump it into your oil supply. If not pour it on moving parts. Not elegant but beats slamming the hose tip onto the drawbar and spraying oil everywhere. I tried the slamming trick, but not enough man in me to get it to work!3000 psi system
Wait for the Lord;
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 4:00pm
Where are you storing the backhoe?  If it gets full sun, the fluid can heat up and lock the fittings up, don't ask me how I know...Wink
Come back in the early AM or on a cloudy day, and sometimes the locked fittings work like a charm...
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 6:34pm
Have that problem on Skid Loader and Snow Plow Shut off engine , cycle the valves , make connection , restart engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 7:05pm
But it’s on the hoe side? When disconnected?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 7:07pm
Originally posted by LouSWPA LouSWPA wrote:
Hmm, so cheap and dirty? Heavy on the dirty? Not much is cheap these days. How about just before the hose tip, put in a tee and a little ball valve on the branch of the tee.   Carry a coffee can with you when you hook up and crack the valve into the coffee can. If you can keep it clean dump it into your oil supply. If not pour it on moving parts. Not elegant but beats slamming the hose tip onto the drawbar and spraying oil everywhere.I tried the slamming trick, but not enough man in me to get it to work!3000 psi system
Bah! Don’t hit it with your purse, act like you mean it!!!🤣. So anyway, what about the tee and dump valve thing? Still too expensive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 8:00pm
Originally posted by Les Kerf Les Kerf wrote:
A quick google search came up with this:
AH Ha! now we are cooking! thank you sir
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 8:06pm
Bah! Don’t hit it with your purse, act like you mean it!!!�£. So anyway, what about the tee and dump valve thing? Still too expensive? I was considering that, except for carrying the can around, until Les came along! and, FOR YOUR INFORMATION, I DON'T CARRY A PURSE! I just carry a clutch!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 8:37pm
You are most welcome Big smile
I remembered reading about those in the Farm Show Magazine some years ago; I have never actually touched one myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 6:38am
Caution on adding a cross connection. What I see most times on simpler hydraulic systems is No Pilot control from one function to another. IE Boom Up or Boom down, or as with outriggers leg extend or retract. Placing a cross connect without concern can lead to a system immediate drain off and the machine settling in a less than optimal configuration, or the potential to fall onto the person connecting hoses.
On heavier or more complex systems they do have pilot valve blocks to block flow from one function to another to ‘Lock’ the major components in position. Simpler systems there is no pilot block set ups to cancel that.
My lawn mower has a loader attachment, no pilot system where will settle and hydraulically end up with system pressure on a cylinder side. Makes a mess every time I connect it back up but is expected.
Edited by DMiller - 04 Oct 2025 at 6:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 6:50am
Dave it lives outside, so your point is well taken.
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 7:23am
A man bag....a satchel.....just please no fanny packs!LOLLOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 2:19pm
Wait for the Lord;
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2025 at 8:41am
My backhoe attachment is self-contained, driven off PTO pump, so I don't have the disconnect problem there, but the FEL on my uncle's tractor DID, and HE had to fight with it same way (sat in the sun, and as Dave said... don't ask how I know...)
Shutting down the engine on the tractor, then wiggling the valves to equalize relieved the tractor side.  Wiggling the valves on the loader side (valves are on the loader side) cleared the bottled pressure on the loader side.
In the beginning, God gave us Plumbing, and contrary to what you MAY HAVE BEEN TOLD, PLUMBING was the ROOT OF ALL EVIL.  Pipes were always in the way, subject to damage, and constantly leaking.  Quick disconnects were a really great invention to add to implements... a great idea, but on the other hand, a bad idea... as they allowed great places for fluid to leak out, and even worse, dirt to get in.  From this came a plethora of covers, caps, shields, plugs in all sorts of materials and colors... then covers, caps, shields and plugs added into the coupling to break off, fail, get stuck, snagged in hoses and PTO shields, then ripped off and lost.  Then came fancy connectors WITH shielding and seals integrated in, again, causing a further schism between mating flavors, and implement manufacturers and equipment manufacturers all picked different favorites, making previously compatible stuff now at-odds.   As companies developed different kinds of QD connectors, there became a great diaspora of incompatible mismatch, wailing, and grinding of teeth...
SO... it was another classic case of a good idea, but a bad idea.
The unfortunate reality of hydraulics, is that it doesn't take much heat for fluid to expand a little, and worse yet, if there' aeration in the fluid (air bubbles) they'll expand too, resulting in residual pressure in the lines.  Having a crossover valve to equalize CAN help, but sometimes it still doesn't... and frequently, it's too much for a clutch or a purse, and if your fanny pack is sideways on your hip, it obstructs the sidearm-sway of the swing, so a medium tote, preferably full of scented candles, rather than three bottles of wine, will work better at slamming those couplers in... but if not, the scented candles will survive still useable, the wine bottles will probably be broken, leaving a stained slurry of broken glass and swill... so bring a straw and a sock to suck it out afterwards, and don't mix your wine flavors- that's a heathen act of unthinkable barbarism that will strip you of your high-heels and little black dress for at LEAST a year.
By the way, be very careful when sucking up the mess, because many hydraulic fluids look very much similar to Cabernet Sauvigion... but it sure-as-heck don't TASTE like it... it'll leave you with the same headache, but it WON'T make the sex any better...Wink
Edited by DaveKamp - 05 Oct 2025 at 8:46am
