Hydraulic question |
Author | |||||
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25218 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Oct 2025 at 5:00pm |
I have a Royal King 37 hp tractor, with the backhoe attachment. If I don't bleed down the hydraulic system, tractor shut down, cycle all controls in tractor and hoe before I disconnect the hoe from the tractor, then I cannot get the quick disconnects reconnected when I setting up to use the hoe again. In that case, I then need to take cover off of controls and open the system to relieve the pressure. PITA!
my question is there something I can put in line that I can relieve the pressure w/o taking it all apart?
I am still confident of this;
Sponsored Links | |||||
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34146 |
Have same issue with a 2305 Deere loader attachment, anything functional would be ridiculously expensive.
Dave, I'm sure you are right, but it sure would be nice to have a manual pressure relief that could be installed in line with the two hoses going to the hoe.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3926 |
pioneer 9500-4 series couplers connect under preasure
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88164 |
could you put a 3000# valve with a couple 1/4 inch hoses between the supply and return lines as a JUMPER... open the valve and relieve the pressure back to suction side ?
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12225 |
Hmm, so cheap and dirty? Heavy on the dirty? Not much is cheap these days. How about just before the hose tip, put in a tee and a little ball valve on the branch of the tee. Carry a coffee can with you when you hook up and crack the valve into the coffee can. If you can keep it clean dump it into your oil supply. If not pour it on moving parts. Not elegant but beats slamming the hose tip onto the drawbar and spraying oil everywhere.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1343 |
A quick google search came up with this:
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54271 |
Where are you storing the backhoe? If it gets full sun, the fluid can heat up and lock the fittings up, don't ask me how I know...
![]() Come back in the early AM or on a cloudy day, and sometimes the locked fittings work like a charm...
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42001 |
Have that problem on Skid Loader and Snow Plow Shut off engine , cycle the valves , make connection , restart engine
But it’s on the hoe side? When disconnected? |
You are most welcome ![]() I remembered reading about those in the Farm Show Magazine some years ago; I have never actually touched one myself.
Caution on adding a cross connection. What I see most times on simpler hydraulic systems is No Pilot control from one function to another. IE Boom Up or Boom down, or as with outriggers leg extend or retract. Placing a cross connect without concern can lead to a system immediate drain off and the machine settling in a less than optimal configuration, or the potential to fall onto the person connecting hoses.
On heavier or more complex systems they do have pilot valve blocks to block flow from one function to another to ‘Lock’ the major components in position. Simpler systems there is no pilot block set ups to cancel that. My lawn mower has a loader attachment, no pilot system where will settle and hydraulically end up with system pressure on a cylinder side. Makes a mess every time I connect it back up but is expected. Edited by DMiller - 13 hours 23 minutes ago at 6:38am |
A man bag....a satchel.....just please no fanny packs!
