Hydraulic question |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25214 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Oct 2025 at 5:00pm |
I have a Royal King 37 hp tractor, with the backhoe attachment. If I don't bleed down the hydraulic system, tractor shut down, cycle all controls in tractor and hoe before I disconnect the hoe from the tractor, then I cannot get the quick disconnects reconnected when I setting up to use the hoe again. In that case, I then need to take cover off of controls and open the system to relieve the pressure. PITA!
my question is there something I can put in line that I can relieve the pressure w/o taking it all apart?
I am still confident of this;
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34135 |
Have same issue with a 2305 Deere loader attachment, anything functional would be ridiculously expensive.
Dave, I'm sure you are right, but it sure would be nice to have a manual pressure relief that could be installed in line with the two hoses going to the hoe.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3926 |
pioneer 9500-4 series couplers connect under preasure
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88129 |
could you put a 3000# valve with a couple 1/4 inch hoses between the supply and return lines as a JUMPER... open the valve and relieve the pressure back to suction side ?
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12222 |
Hmm, so cheap and dirty? Heavy on the dirty? Not much is cheap these days. How about just before the hose tip, put in a tee and a little ball valve on the branch of the tee. Carry a coffee can with you when you hook up and crack the valve into the coffee can. If you can keep it clean dump it into your oil supply. If not pour it on moving parts. Not elegant but beats slamming the hose tip onto the drawbar and spraying oil everywhere.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1342 |
A quick google search came up with this:
