Hydraulic question |
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25212 |
![]() ![]() ![]() ![]() ![]() Posted: 16 hours 27 minutes ago at 5:00pm |
I have a Royal King 37 hp tractor, with the backhoe attachment. If I don't bleed down the hydraulic system, tractor shut down, cycle all controls in tractor and hoe before I disconnect the hoe from the tractor, then I cannot get the quick disconnects reconnected when I setting up to use the hoe again. In that case, I then need to take cover off of controls and open the system to relieve the pressure. PITA!
my question is there something I can put in line that I can relieve the pressure w/o taking it all apart?
I am still confident of this;
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34132 |
Have same issue with a 2305 Deere loader attachment, anything functional would be ridiculously expensive.
Dave, I'm sure you are right, but it sure would be nice to have a manual pressure relief that could be installed in line with the two hoses going to the hoe.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3923 |
pioneer 9500-4 series couplers connect under preasure
