Hydraulic pump seal
Message Reverse Sort Order
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic pump seal
    Posted: 29 Dec 2010 at 12:14am
Well, according to my manual, the front seal for a 190 pump is not the same as the 180 pump seal. Seems it is a seal assembly. Anyone know where to get one. Don't have an AGCO dealer close. If just the seal can be changed please let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 3:09pm
Thanks. I should be able to look that up. Dave
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:32am
Dave, I have the old seal from my 180 in front of me.  I would assume they are the same.  No number. The demensions are-.250 thick-1.375 OD-.875 ID. They are a hi-pressure seal. I hope this helps. Happy New Year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 11:19pm
I need to know what the National number is for the shaft seal for the hydraulic pump on a 190XT. I have the AC number somewhere but need a National or CR number. Or just the dimensions. I probably have a seal for it but don't want to take the pump off without knowing for sure that I have a seal here. I use this tractor about every day.
