hydraulic pump on WD 45 |
J. Larsen
Joined: 01 Dec 2023 Location: Lander, WY Points: 47 |
Topic: hydraulic pump on WD 45Posted: 07 Dec 2023 at 2:07pm |
I'm getting closer, I show 2 pics of the WD45 and the hydraulic lines as they currently exist. Do I need to do 2 seperate posts and just put 1 picture on each post? I'm trying to figure out how to get the lever on the left side to operate the 3 point. Currently, the lever is inoperative, although it is hooked up to the linkage on the hyd. pump. The way the 3 point works now is strictly with the control valve lever to the left hand of the seat.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 07 Dec 2023 at 2:34pm |
You need to close the valve by the corner of the battery box.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 07 Dec 2023 at 8:09pm |
to little of a picture for me very clear , dont know why its hooked to that valve by the seat ,what does the rod the rod on the pump hook to thats what turns the pump off and on the valve by the seat would only work when the pump is on , the valve buy the seat has to return the oil back to tank or they will not go down unitl you put the pump in lower position and then let it down with the lever by the seat . it needs the hoses put back on the pump where they belong and get rid of that valve by the seat unless pipe like you aregoing to have a pair of remotes
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 07 Dec 2023 at 10:44pm |
That is a mess! I can't figure what they were trying to accomplish with all that. Factory setup would work the 3 point just fine.
