Hydraulic pump for Model C |
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Topic: Hydraulic pump for Model CPosted: 20 Sep 2010 at 8:27pm |
Ron, If you have a very early B yes as Charlie says you will first need to upgrade your PTO/Belt pulley. You can easily see if you have the lobes without removing the cover. Look and see if it is a small round cap with no bolts or if it is a square cover bolted on it will have lobes. If that is the case all that is needed is a pump, ram, and if you wish to have a two way plow a LH ram and a selector valve and some plumbing. You may find this on the vendors who advertise here or you can check on e-bay under Allis Chalmers. Sometimes one pops up. Good Luck! Bill Long |
RON P
Posted: 20 Sep 2010 at 3:05pm |
Thanks for the info will check for the lobes.
CTuckerNWIL
Posted: 19 Sep 2010 at 10:19pm |
I don't know about the C, but some of the early B's that didn't have hydraulics, didn't have the cam lobes on the pto shaft to run a hydraulic pump. You might want to pull the plate off (under the seat) where the pump bolts up and see if there are cams on the shaft.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 19 Sep 2010 at 10:02pm |
The pump is mounted on the rear pumpkin and is driven off the PTO shaft. The Allis pump is Hi-Pressure, low volume; especially the one that came with the C. Pump is the same same the B series Allis.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
RON P
Posted: 19 Sep 2010 at 8:20pm |
I have just purchased a Model C without hydraulics. I plan to add a three point hitch.
I am unsure on where the pump was mounted.
