Hydraulic pump and ram capacity
JTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTS Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic pump and ram capacity
    Posted: 28 Jan 2026 at 9:51am
I inherited my father's WD45 and am rebuilding it. Apparently he changed the hydraulics from the back of the tractor to the front to operate a snow plow. I replaced the single unworking ram with two new large rams. (The plow is extremely heavy). I've gotten everything running and no oil pan leaks, but now I have a leak coming from behind the fly wheel cover. I believe it is either a faulty gasket between the hydraulic and bell housings leaking oil from there. Or the rams I bought are way too big for the pump to handle, creating too much pressure. I've looked in all three manuals I have and online to find the capacity of the hydraulic pump on this tractor and what size rams can be used, but have found nothing. Is anyone familiar with this or can possibly guide me in the right direction? I'm hoping the rams are too big because I'd rather not have to split the tractor to replace that gasket.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 2:30pm
The leak is not related to the cylinders.  Most likely the input seal on the torque tube needs replacing - could also be the rear main on the engine.  Either way, you will have to split it.
Those new cylinders are probably not going to work.  The hydraulic system is a high pressure/low volume set up.  New cylinders are the opposite.  This means they will move very slowly.  Stick with the original cylinders that were made for the tractor.  They will work well and are very strong!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 3:34pm
The hydraulic sump only holds 6 quarts of oil to begin with. If you have two double acting rams larger than 1 1/2" you might be overfull of oil and it is leaking out the vent hole, which happens to be inside the bellhousing above the clutch shaft. Check the hyd oil dipstick while rams are fully extended AND fully collapsed. It can't be overfull or it will leak.
JTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 5:27pm
I don't have the original cylinders. Can I get new smaller ones that will work? I don't even know what size the original cylinders were on it. I can't find that info anywhere in my manuals. But I'd love to have the correct ones on there.
Checked the dipstick, it's dry. I'm pretty confident its the seal on the torque tube, not the rear main seal. If I have to split it regardless I might as well do both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 6:52pm
The original lift arm rams were 1 1/4" diameter. They should readily be available from salvage yards around the country and are more than capable of handling the 3000 ++ psi that the hydraulic pump can develop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 7:16pm
I have a few original WD/WD45 lift cylinders in good condition.  I'm located in Maryland, close to Gettysburg, Pa. These cylinders could ship. PM me if interested.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2026 at 10:32pm
sounds like nyou nare trying to run double acting cylinders up front and retracting them to liftthat is going to send double the volume back to tank from the big side ofthe cyldiner
