Hydraulic Pump Allis Chalmers C |
John426
Topic: Hydraulic Pump Allis Chalmers CPosted: 1 hour 38 minutes ago at 10:49am |
Hi
On the hydraulic pump of the model C ; there are 4 balls - 2 balls for intake valve item 27 , ref number 70915904 , 5/16" , is it correct? - Another one is the discharge valve ball. But no Item ? and of course no piece number. - And the last, Releif Valve item N° 7 reference 70915906 . This should be smaller only 3/16" does this size correct ( the others are 5/16") What is the reference of this discharge ball? Or the diameter size Or i am a little confuse , may item 2 with the Insert assy 70213522, there is a second line with Ball discharge same reference than intake, but they put qtty = 2 ? why i see only one? ?Edited by John426 - 1 hour 20 minutes ago at 11:07am |
