Hydraulic pump 7000-8000 series |
Post Reply |
SilverShoes
Bronze Level Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 115 |
Posted: 05 Jul 2024 at 11:23am |
Does anyone know who manufactured the hydraulic compensator on the piston n pump for these tractors?
Orange Level Access Joined: 12 Sep 2009 Points: 20247 |
I thought the piston pump was a Cessna, so I assume they built their own compensator.
SilverShoes
Thank you, just messing with a tractor with no pto pressure and thinking it could be the compensator. Agco is a grand for a new one and was thinking I could search a little bit and see if I could find one at a jobber maybe
Well, if the PTO doesn't have pressure, you must have other things not working right either, like poor brakes, diff lock pedal won't stay down, etc. WHAT MODEL ?? Many times the low pressure spool needs a couple of shims to fix them, not a whole compensator. What is your "stand-by pressure ???????
MikeKroupa
Bronze Level Access Joined: 12 Sep 2009 Location: pierce,nebraska Points: 77 |
Doc is correct, Cessna supplied the piston pump. I had the low pressure spring break in my 8550, probably 30 plus years ago, the one offered by AGCO was the adjustable type, so updated to it. Good Luck !
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2259 |
I don't recall ever having to replace a compensator on a 7000-8000 series. Springs can break and shims can also break or just need to be added. The later style, screw adjustable, can break the screws and then the pressure backs off. Sometimes the piston pump itself, is the problem.
NEVER green
Orange Level Access Joined: 28 Feb 2013 Location: MN. Points: 7265 |
I have a good pump for sale.
SilverShoes
Hello, how much for your pump? Where are you located. Just curious, never know when one might be needed
Edited by SilverShoes - 06 Jul 2024 at 10:28am |
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8387 |
If you need a pump from one of these tractors rebuilt, I recommend this place. They can rebuild all 3.
https://stoens.com/ |
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8626 |
Thanks Creston. I don't need anything from them now, but I sure hope that I can keep that place stored in my memory for future use. Darrel |
SilverShoes
Thank you for the contact
NEVER green
Sent you a PM.
Unit3
Orange Level Joined: 17 Oct 2009 Location: NC Iowa Points: 5529 |
Before you dive in too deep, put a load to each of your hydraulic valves. I went through this on the 7045. I had one that lifted slow. The valve had a crack in it.
Post Reply | |
