Hydraulic Port O rings |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12016 |
![]() ![]() ![]() ![]() ![]() Posted: 22 hours 59 minutes ago at 4:16pm |
I’m confused. Just when you think you know….
The old Deere style outlets take an o ring different than ISO / Pioneer style. One has a square cross section, one round. Which is which???!! |
dkattau ![]() Silver Level ![]() Joined: 20 Mar 2011 Location: Nebraska Points: 277 |
The Deere cone tips, from ‘61-‘84, used a round ring and backup ring. Post ‘84 ISO tips used the square cut quad ring and backup ring.
Thank you!
That’s sort of what I thought…..but, dad swore it was the other way. Plus, we had a pack of each labeled wrong from a dealer. Plus the tractor I worked on before this had some of each. Plus the one I just took out was so messed up I couldn’t hardly tell. Plus, had a helluva time getting the square one in there! Been told you don’t really need the backing ring, but does it go on the tractor side or hose side? |
Hose side, away from the tractor. The backup ring is just there to keep the o-ring or quadring from rolling in the groove. If you don’t ever uncouple the hoses, you can leave the backup ring out.
You can use o-rings in the ISO couplers, that’s all the Pioneers used. The quad rings are supposed to hold a seal longer. Whether they do or not is still up for debate…
Well, I’ve got one of each in #3! Guess that’ll be a good test. Thanks a million for the info. |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2302 |
I purchased sealing ring kits from amazon in both SAE, Metric, and square cut styles from very small to very large. About $40.00 for all I have and they get used often as I see quite a bit of SAE fittings, and Ag fittings along with some code 61 flange fittings.
That's All Folks!
Side note, I have never had that much “fun” taking an o ring out!😡😡😡🤬🤬
