Hydraulic oil |
Stoges
Topic: Hydraulic oilPosted: 20 Apr 2025 at 8:18pm |
Not using the hydraulic in a WD pulling tractor, do you need to keep oil in the system.
AintCheatnAintTryn
Joined: 27 Feb 2025 Location: pennsylvania Points: 24 |
Posted: 06 May 2025 at 5:16pm |
Most dedicated pulling tractors in my area drain the fluid and pull all the hydraulics.
Posted: 06 May 2025 at 6:16pm |
This is a funny post. On April 20th you asked the same exact question and I told you there was a clutch shaft bearing inside that hydraulic compartment. Keeping 6 quarts of oil in there weighs 9 pounds and sees to it the bearing will never ever fail. Good luck !!
Edited by DrAllis - 06 May 2025 at 8:19pm |
