Hydraulic Motors and WD45 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 8:34am
How would you use the remote on the lift for the combine if you are going to use it for the reel? You could use a diverter valve, but you would have one or the other working. If the only time you need the lift was on the end of the field it might not be a problem. Set your head height, divert to the reel and go through the field. When you get to the end, switch back to the remote and the reel would stop, and raise the head.
 If RPM's don't work out right , you could always reduce the reel speed from the motor by use of a belt and pulleys.
Edited by CTuckerNWIL - 05 Nov 2010 at 8:35am
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:05am
Tom, I may have missed the solution here somewhere.  The onboard  Hydraulic system on the 45 is one way out and gravity push back through the same line.  For a motor you need constant out and constant back.  Two lines.  i have seen this done with a makeshift return line to the hydraulic filler port.  If you are just looking for independent reel rotation, go electric from the tractor's battery system.
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:16am
My remote valve has a shutoff. Set desired header height, shut the valve closed. Then I can adjust hydraulic power to get the reel motor at the desired speed without affecting the header height.  Of course if I need to change the header height, I would have to stop operations, open that remote valve and adjust height accordingly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:17am
Yes I would plumb a line back to the hydraulic tank. There is a hyd tank drain plug if I am not mistaken. Would use that as my return port.
Electric would be an option too...but try finding a 12v DC motor that runs at 50 or under RPM's.. I suspect I would need additional hardware to do it his way....I dont want to get too complicated here. Perhaps just adding a belt from the draper drive would work.
Here is a electric motor I found:
Not enough torque it appears...
Edited by TomYaz - 05 Nov 2010 at 9:25am
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:34am
Do you intend to have the reel driven by the motor directly or via a chain or belt?  If you connected a gear reduction to a motor you would increase its torque and decrease its RPMs.  That means that a smaller motor could do the job.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 9:51am
Several problems with using WD hydraulic system which have been mentioned.  Another would be the need for a radiator to dissipate heat as the tractor was not designed for continuous flow of oil.
I suggest you look into the self-contained system mounted on the combine like Kev mentioned.  If you can, go look at a grain header for a Gleaner conventional (and some rotary) combine from the late 70's through early 90's.  They had a chain driven pump, reservoir, and motor all mounted on the header.  Some of these heads are obsolete or trashed, but still have good hydraulic systems.  Best of all, there is an electric control hooked to the pump so you can vary the speed with a rocker switch.
JimIA has about 4 of these heads sitting in the weeds out back.  He could probably help you out.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:03am
Russ (and Roddo)
Thanks for the info. Well, sounds like for a WD45 its going to be more BS than I want.  I suppose on a modern hydraulic system this would be a slam dunk.  I want to develop something simple and realtively cheap and incorporate on a rebuild.  Maybe if/when I get a modern tractor I can revisit this and develop something for modern hydraulic systems. Till then I am going to go with a extra pulley/belt get up.
Edited by TomYaz - 05 Nov 2010 at 10:04am
smuggler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smuggler Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:13am
Tom surplus center has 12volt motors ,    item number 5-1719 or 5-1720. 40 rpms  , hp rateing is pretty low tho  the 5-1720 is rated at 1.2 hp 1890 in lbs of torque,
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:42am
Either of those motors would come close to working. Yes, you divide inch pounds by 12 to get foot pounds. 50 inch pounds is about how hard you can turn a screwdriver handle. 4 foot pounds.
You can protect a motor from over pressure with a pressure relief valve in parallel with the motor. I'm sure surplus center sells one suitable for that purpose. In their 2007 catalog which is the first one I found this week, look at 9-6597, 9-4127, 9-1556, 9-7375 or 9-4492 or search for relief valve. For that matter, all open center control valves unclude a pressure relief valve.
Not having run a combine, I'm not sure of the reel speed, but I'd think like my mower conditioner you'd want the peripheral speed to be just a hair faster than the ground speed so as to push the crop into the sickle and drop it on the belt top first. ON my PT-10 mower conditioner there's a bar above the sickle and in front of the reel that leans the crop away from the sickle so the reel flips it up to the conditioner rolls cut butt first so it goes through best. And you want that a little bit faster than ground speed to keep from there being a build up of crop over the sickle. You don't want the reel swatting the crop to knock seed off the straw, that's the job of the innards of the combine where that flying seed gets caught.
So you probably harvest at something like 3 mph and the reel is 5 feet in diameter. Makes it 15.7 feet circumference. 3 mph is 15,840 feet per hour, 264 feet per minute, 16.8 RPM. So you probably want about 20 rpm. 50 rpm is good for feeding the birds, not putting crop in the hopper.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 10:47am
Gerald J.
Well if correct, that changes things...and I was just looking at smugglers suggestion:
Problem is, dont think I can get 75 AMP out of the slow running alternator to power this... and 40 RPM may be too fast...
*sigh* never easy is it?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 11:42am
Here's my 2 cents worth.
If you are determined to hydraulic drive the reel, why not ground drive a poitive displacement pump and run your reel motor with that? I'm not good enough with hydraulics to tell you what pump/motor combination will work, but it will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 12:41pm
Nope not really determied to drive it w/hydraulics, just determined to drive it with something besides the wheel..But if the combine isnt moving, wouldnt that pump not be working?  If so, I'm no better off.
Edited by TomYaz - 05 Nov 2010 at 12:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 1:16pm
Ground drive as it came from the factory has some advantage automatiically varying as your ground speed varies. Seems to me that keeping the reel running with very slow forward or no motion just gives the grain reason to drop to the ground when tapped or urged by the reel towards the sickle, but when it can't move.
Gerald J.
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 3:45pm
Because that would be too easy!!!  Was looking at a hydraulic solution as faster way to get there and provide variable speed option
Mount a step pulley..3 speeds?
Life is short...Make haste to be kind
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 3:55pm
Tom - I assume you are looking to be able to independently adjust reel speed.  Does this need to be done from the tractor seat?  If reel speed needs to only be adjusted from the combine, then why not put a modified salisbury clutch(Comet) setup on and run from the draper drive.  This is the clutch type used on minibikes. - AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 8:19am
Tom, you could very easily make a variable speed drive for the reel out of the variable sheaves from a Ranch King or MTD lawn mower. Drive off the ground wheel and add the variable sheave in between driver and driven just like on the lawn mower. Run a control rod to within reach of the tractor seat. All you would need to add would be a notched plate to hold position or a friction set up to hold position. Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 11:39am
Chas,
Dont want to drive anything off the ground...trying to get away from that so that I can always have the reel spinning regardless if ground wheel turning. The variable part is a nice to have; not a  need to have.
Thanks anyway!
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 6:55pm
My 2 cents."Peeing in the wind".I've dreamt up many improvement ideas over the years because it would be "neat" but the reality was always the same.To what end?Don't want to spend any money to do it right but difficult to figure out anything less.Bottom line is,it worked well enough "back in the day".If your not moving,the reel doesn't need to either.Don't misunderstand,I've been where you are but sometimes it just ain't worth it.When my dad went from a 60 to a 90 I thought that continuous reel was cool but I don't know that it made a real difference.When I had my A2 I thought a variable reel would be great!Have it on my F2 and it's just okay.Seldom need to use it. Anyway,take a chill pill and relax.Life is too short to sweat the small stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2010 at 7:05pm
Steve,
I agree with you sentiments...Tahts why I was trying to figure out a relatively "easy way" to do it. Got a lot of suggestions but many not worth the trouble for the expense involved. I think the simplist thing would be to tie in with the draper drive pulley. We shall see...Im not doing this so much for myself, but rather something that could be offered to my customers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 9:27pm
Been too long since Ive been around a 60 or a 90 but they figured a way to power the 90 reel off of live shaft some where.Might be able to engineer a kit similar to add on.
