Hydraulic issues
Nickwag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nickwag Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic issues
    Posted: 06 May 2018 at 5:20pm
So I bought a allis dozer hd11e and it's getting transsmisson/Hydraulic fluid in the engine. Thought it was a seal on the pump so fixed the seal but now I have no steering and it's still putting transmission/ hydraulic fluid in the engine. Before I fixed it the steering clutches ran like a dream. Any help would be awesome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 5:47pm
Which pump? There are two, one for the trans on the torque converter and one on the engine for the steering clutches/brakes. And is the unit a EP?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 5:51pm
Have you been on Minnpars website? Go to this catalog and pages 212 up for First type/second type. The steering pump is Engine timing cover mounted and usually ABOVE the trans oil level so ANY air inleakage will cause grief, loss of that pump's seals will put oil in the engine directly.
http://files.minnpar.com/partbooks/CRAWLER%20AND%20WHEEL%20DOZER%20MANUALS/ALLIS%20CHALMERS%20%2C%20FIATALLIS%20CRAWLER%20DOZER%20MANUALS/HD-11EP%20PM%20%2370651804.PDF
Edited by DMiller - 06 May 2018 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nickwag Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 6:41pm
Thanks, no it's not a ep, it says hd11 e-ag. It's the steering clutch pump that I replaced the seal on. And thanks I will go check out that website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nickwag Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 6:42pm
And their is no torch converter.
This page was generated in 0.119 seconds.
