Hydraulic fluid
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic fluid
    Posted: 20 Apr 2025 at 8:22pm
Do I need to keep hydroulic oil tank of a WD puller, never using the hydraulics.
Thanks Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 10:32pm
You can remove the hydraulic pump assembly and make a cover for the open hole. There is a clutch shaft bearing inside the torque housing (not a tank) that has to have oil, so you better fill the housing up to the dipstick. Takes 5 to 6 quarts of oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 6:27am
Thanks Doc
This page was generated in 0.110 seconds.
