Hydraulic fluid questions???K |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: Hydraulic fluid questions???KPosted: 01 Nov 2021 at 12:44pm |
I have a 1900 Ford 4x4 tractor. I just drained the hydraulic fluid and cleaned the filter.
It calls for 134 universal tractor fluid. It runs in the transmission and rear differential. Can I use universal tractor fluid from Tractor supply or such. New Holland is $75.00 for 5 gallons and TSC has an off brand for $30.00 I need 12 gallons. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 01 Nov 2021 at 1:55pm |
The "134" Ford fluid is much like the universal HyTran fluids that are out there. It is the recommended fluid for the SOS transmissions. The "2C53" is a heavier weight.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 01 Nov 2021 at 2:07pm |
FWIW...I've been using the WallyWorld UTF for years in 3 D-14s.... It's a LOT closer than TSC ( which got bought out by someone....) here in Ontario
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 01 Nov 2021 at 2:44pm |
On the TSC Universal Hydraulic Fluid lists what manufacturers tractors it is compatible with. Most equipment uses the same Hydraulic fluid whether it is IH Hytran,Allis Chalmers 831 or John Deere Hy Guard. Newer equipment uses different fluid and should be checked for compatibility.
fixer1958
Posted: 01 Nov 2021 at 3:10pm |
I think New Holland is intent on cleaning out your bank account. Bout did mine for 'can't find anywhere else' parts.
Have a Ford 1320 4x4 all hydro and have run AW32 from Oreally and Napafor 10 years without any issues. Only other fluid is the front diff and engine.
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 01 Nov 2021 at 4:03pm |
I agree with Mark... Check the label on the TSC bucket for spec... The "very cheap" stuff will have very little specs.... You can get a "good quality" generic in the $30 - 40. range.. It should meet several different specs from JD, Allis, C4, TO2 , Case, etc.... If it meets 20 different specs, its a good quality oil.
Edited by steve(ill) - 01 Nov 2021 at 4:08pm |
Posted: 01 Nov 2021 at 4:06pm |
I looked up TSC Hyrdaulic oil.. They list a "VP" and this is what is says... i would use it.
