Hydraulic Cylinder
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Cylinder
    Posted: 13 May 2010 at 11:46am
I bought a replacement cylinder for my disk. My old cylinder is a one-way (port on one end of the cylinder only) and my new cylinder is a two-way. Do I just plug one of the ports or do I have to put a vent in the other ports to let the air in and out?
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:50am
You need a vent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 12:49pm
From what I've seen a vent is a just plug with a small hole drilled in it.  Maybe there are some more sophisticated vents on some with a screen to keep dirt out better.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 4:35am
The vent plugs were available in the past, maybe some dealers will have one.  I have used an pipe elbow with a rag wrapped around it, didn't look real pretty but worked.
I have made a vent with a brass pipe to flare fitting, topped off with drilled cap(parts I had in the scrap box.  I think I drilled a 1/16 hole in cap.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 7:31am
Most any store that has hydraulic fittings will have a vent fitting. It has a fine screen in it to keep out grunge from being inhaled. And it lets the oil out when the piston seals leak. Last one I bought cost around $3.95. Carried by Northern Tool, Baum Hydraulics, probably TSC, Farm and Fleet, Deere, AC, etc. Comes in several threads, like o-ring or tapered pipe thread, amost certainly in1/2 and 3/4" sizes of each.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 7:46am
Here is something that will work great. We used them as mufflers on air control valving on presses and other machine tools. They also work great for the back side of your cylinder.
http://www.pneumaticdepot.com/products.php?category=Pneumatic%20Exhaust%20Muffler&type=A&osCsid=a372c5e8ac341d00c2bbcf010f2abf38
This page was generated in 0.128 seconds.
