Hydraulic Cylinder End Cap |
bauerd44 ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Feb 2021 at 3:13pm |
On my AC 500 loader, the lift cylinder gland nut at the end where the rod come out, is always backing out, and if I don't see it, I am going to have a mess. How tight do you make the nut. I have always used a screw driver to tighten up. I do not have a spanner wrench that will fit. Thanks Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
use a hammer and punch , get it tight. MACK
old farmer ![]() Silver Level Access ![]() ![]() Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
You can make a spanner wrench by cutting with a torch and then drill holes to fit your needs. Fit pins to size. Weld in place. We have made several this way.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24643 |
no torch ???... cut 3 pieces of flat bar, weld into a 'U'(inside of u just bigger that OD od ram., add a handle...looks like a 'Y' or goalpost now.. fun part weld tabs ont he unprights of the 'U' to fit the 'pinholes' of the nut. One of those ,after it's built ,it's easy to see HOW to make one......
