hyd pump |
shameless dude
Topic: hyd pumpPosted: 29 Jul 2021 at 9:40pm |
where on a 190XT is the pump that runs the hyd's? the steering works, the 3-pt works, but it won't raise a disk or plow on the hyd cylinder. i don't want to replace the wrong one.
youngorange2000
Joined: 27 Mar 2019 Location: eastcentral MN Points: 319 |
Posted: 29 Jul 2021 at 10:26pm |
It's all one cam driven pump with flow divider valve. It's on the front driver's side of engine.
MACK
Posted: 30 Jul 2021 at 6:17am |
Sounds like you may have a relief problem. There is two on valve stack below the levers. Switch places with them. MACK
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 30 Jul 2021 at 9:30am |
The earlier 190's used a triple section pump without a flow divider.
Posted: 30 Jul 2021 at 9:41am |
The original triple section pump had a flow-divider/priority valve located vertically on the back of the pump to see to it the power steering and Power Director/PTO circuits always received 4 to 5 GPM's at all engine speeds and the excess flow was recirculated back into that sections inlet.
shameless dude
Posted: 31 Jul 2021 at 2:05am |
thanks!
