Hyd cly on a 415 loader
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Topic: Hyd cly on a 415 loader
    Posted: 05 Jul 2024 at 3:38pm
I've a 415 Allis loader on my D15 with the front mount pump and put a quick attach on her and thought I could lift a pallet weighing about 2200 lbs, no go would take a little weight off the trailer but not enough to be able to get it off of the trailer, here are my cly dimensions lift cly bore-2.339, rod-1.515, stroke-31", tilt cly, bore-2.318, rod-1.50, stroke-20", the pump should be rated at 2000psi.
 What size cly would I've to go to to be able to lift up to 2500 lbs or is there anything else I could do to the old girl to make it work. TIA.
Edited by Kenny L. - 05 Jul 2024 at 10:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 8:34pm
A 2.500" cylinder has 15% more power than a 2.300" cylinder. A 2.750" bore cylinder has 30% more power than a 2.300" bore. All are figured at 2,000 psi pressure.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 5:51am
I've got a TA 46 I'll sell you, put it on that 8030 and you'll have all kinds of lifting capacity!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 6:14am
Have a look at the Allis Model 615, the Industrial version of the D-15.
Note the heavy duty Loader Boom, the stronger Industrial Front Axle, the bigger lift and tilt Cylinders.
All things to consider if lifting a heavier load.
Gary
https://www.allis01.com/fossto/69-615/ac-69-615.html
https://www.tractordata.com/backhoe-loader/000/0/9/94-allis-chalmers-615.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 7:16am
I'm sure there was someone on this site that found/bought new boom cylinders for a 400 or 500 loader that were a little larger in bore diameter ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 7:59pm
 Mike,give me a call when you can.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 9:58pm
I don't believe the 400/500 loaders were designed to lift 2000 lbs.
Not that it can't do it on a larger tractor but on a D15... not safe..
I have an I600 industrial same as D15. But solid front axle and shuttle.
Loaded tires and 1000 lbs on the 3 point. Solid and stable wit 10:00 x 16's on the front.
It will lift 1500 lbs round bales but not something i do regularly.
I believe your cylinders on your loader are rated to help keep you safe.
IMHA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 10:03pm
FYI
I have a set of cylinders of an I600 industrial if you are interested ?
They came off an operating machine and was keeping them as spares. I never needed them.
I
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 8:50am
Hey Kenny
I replied to your PM .
A d included my cell #.
Trxt me and ill send you the info you requested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 6:39pm
To update the post I decided to buy a skidloader instead of end up abusing the old and breaking something like the kneels or worst. Thanks for all the reply's
