hx35 core?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: hx35 core?
    Posted: 24 Jan 2015 at 5:37pm
Is there any value in a hx35 turbo that was replaced because itvwas loosing oil into the engine? It was removed from a tusk 10k lb. Forklift with a 6 cyl Cummins.
studer automotive View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studer automotive Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2015 at 11:34pm
Not a whole lot, they are pretty common
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4
86 mustang5.0 owned since 8/93
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2015 at 8:32am
OK it just seemed too good for the scrap pile. The new one cost round $2k.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2015 at 12:56pm
Does it have the waste gated exhaust housing? It's not worth much, but is worth something. Don't throw it in the iron pile just yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2015 at 3:58pm
I'm not sure I'll have to look again. I don't know a lot about turbos, there is a place where there is three holes two outer are tapped, I assumed it was for an oil line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 5:18pm
Looks like a no on the waste gate. So now what's it worth?
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 6:09pm
put it in the "Healing Bay" with the rest of your half worn out parts and forget about it ! ! ! Wink
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 8:22pm
Ya I'll toss it on the shelf...ya never know. Can they be resealed easily?
MATPA47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MATPA47 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 6:40pm
They are cheap to reseal, I usually have a pump shop do it because i don't have the right tools,
