Hustler RAPTOR
AllisD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD14 Quote  Post ReplyReply Direct Link To This Post Topic: Hustler RAPTOR
    Posted: 13 Feb 2026 at 7:47am
Hello Forum brains.
I've tried on line support with no success. Then I recalled I have access to the entire USA for direction on most engine issues. Hopefully someone can direct me.
There is a summary below of all that I have done. Honestly, there are dealers with a few miles of me with labor charges $100/hr which I would like to avoid. Especially if I can manage the repair. I'm a novice in mechanics so if someone replies talk as you are a teacher in a class. LOL.
Engine will not crank. Battery? - fully charged. Solenoid? replaced not long ago and there is no "click, click, click" like a solenoid failure. Key and switch? replaced. There is a faint click. Safety interlock switch replaced. Nothing. Listening again, the faint CLICK appears to be in the harness under the right side, on the switch key side.
Hustler Raptor model 935759 purchase date March 2018.
Am I on the right track? What have I missed?
Thanks
Julian from eastern NC
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 1:21am
Since nobody else has chimed in I'll mention a few things. I know nothing about the Hustler Raptor, but did find manuals online. In the operators manual on page 4-2 it mentions a fuse, I would check it first. It also mentions several safety start interlock switches on page 3-2, not just the seat switch but also park brake switches and a deck clutch switch. If you look in the parts manual there are also two relays in the wiring harness, but I didn't find a wiring diagram so it is only a guess that one of them may run the start solenoid. If it were mine I would be a little confused at this point, and I would be a little hesitant to just start throwing parts at it. If it is not the fuse you need to start testing things. If you don't have a tester it would be a good investment. I have a combination test light/circuit tester I like to use that has LEDs to tell me continuity or voltage, with 3 different lights for 6, 12, and 24 volts, plus two lights for straight or reverse polarity.
In short, several different things that could be wrong. Without a wiring diagram it is difficult to say exactly where to test, but if you can locate all the safety switches and check them it would be a good start.
Ted
Edited by TedN - 14 Feb 2026 at 12:40pm
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7045, 190XTD series??? project(or maybe parts)
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 1:42pm
I would check the battery cable for corosion and rust
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2026 at 8:46pm
Simplicity, and JD have both had issues with low voltage going to wire to engage starter solenoid (voltage was weak by the time it got through safety switches). I would check voltage where wire connects to solenoid to see if it has at least 12 volts. The work around is to install a relay near starter, that only controls solenoid circuit. I believe the JD kit is one of the better priced one.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 6:22pm
i have several customers customers with hustlers by the way i am much more than 100 an hour verify power to the startersolioniod then verifiy poweronthe back ofthe keypower in power on start then move  down to the safty swithces theymake up the relays to send power to make the starter soliod work
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD14 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 7:23pm
HUDCo
My apology for how my initial request sounded regarding labor costs for small engine.   It was intended as a request for "education" if it was something that I could learn. I use local people when needed. Again, my apology.
Also, thank you for your directions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 10:10pm
the hustler web site should have your wire schematic on there when you look up the parts and or operators manual   the one hustler i did last year the owner hooked the battery up backwards snd fryed the entire chargeing system and got a wire in the starting system  other than that,       the hustlers are areal good smart enginered machine and tough that s  my opinion on them
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD14 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 6:14am
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2026 at 10:01pm
I had trouble with no start (no nothing) when twisting key on my 05 Simplicity zero. It's got more safety switches than you can count. I finally went to every one and removed wires from connector and gave each a good hard crimp and that fixed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 14 minutes ago at 9:24pm
I am betting you have an interlock causing low voltage. My Jacobsen does it most of the time. I just jump it off. HTH Tracy
