Husco valve assembly |
Allis_Cooper ![]() Bronze Level ![]() ![]() Joined: 05 Oct 2021 Location: FL Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jun 2024 at 7:52am |
Hello, I am seeking a seal kit for the remote valve assembly on my 1975 AC 185. The tag on it (as best I can read it) says: Husco E000375 I've tried an AgCo dealer but they haven't gotten back to me. Does anyone on here know where to get such a kit for this assembly?
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Illinois Points: 1915 |
I really would suggest you remove the valve and let a qualified hydraulic shop do the work. Husco is a good valve but like any, they wear in the bores and spools and a good shop can hone bores and rebuild spools if need be.
Of course any good hydraulic shop can supply you seals also only.
A career built on repairing and improving engineering design deficiencies, shortcomings, and failures over 50 years now.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19761 |
70255229 is a seal kit for ONE valve section. 70261795 is a seal kit for ALL sections I think. Spools are made for a specific valve block and cannot have anything done to them like polishing or lapping.
It is usually much less $$$ to machine new spools from purpose supplied raw stock than build up and regrind to dimension; though it can be, and is done. Bores are usually bored and reamed/lapped oversize, or sleeved than lapped to proper dimensions if bad. Did a lot of this work as an apprentice in years gone by. Same principal with transmission shift rails and bores they slide in.
