How useful is a Hydraulic Top Link?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Topic: How useful is a Hydraulic Top Link?
    Posted: 19 hours 34 minutes ago at 8:52am
Ordered a new quick hitch for my tractor, (Cat II with Cat I hooks) to make it easier and more useful with different implements. I always need to adjust the top link to keep the implement level which at this time is a car, and/or utility hauler trailer, rear tiller, post hole auger, rear mount mower, etc. I'm adding to this inventory when something is needed as I don't like to borrow things.
Thanks,
That's All Folks!
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 50 minutes ago at 9:36am
They are super handy when box-blading! Change angle of blade at any time without leaving the seat.I put power beyond and aux controls on my compact utility tractor just to add this feature, and it was well worth it. Installed a 2-spool valve block so I’ll have an extra control ready to plumb in when I finally get a grapple for the loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 22 minutes ago at 2:04pm
Ah yes, I remember well when having a three point box blade the adjustments to the top link to get desired result. I don't have one any longer as went 1/2s on an 8' wide tongue pull one with hydraulic elevation. Partner has a very long gravel drive and this is used maintaining that and the occasional grooming of my parking area. It does a nice job being independent of the tractor.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 6 minutes ago at 8:20pm
Just purchased one for our fence stretcher that I use on my 160. It worked great, highly recommend one. Worked well for the 3pt fertilizer spreader last week also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 33 minutes ago at 8:53pm
You are using it as a "pull in" hydaulic puller? I can see that working very well for that purpose. What kind of hydraulic pressure does a 160 make?
That's All Folks!
