how to use a transport valve
playsindirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Topic: how to use a transport valve
    Posted: 13 Jun 2015 at 7:42am
I would like to know the right way to use a transport valve.
48G 49B 67D15 35picker allcrop60 1973 rotobaler 49C
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 8:29am
First things first.   Are you pulling a mounted implement with its own transport wheels such as a large disc or a plow with a trailing wheel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 1:49pm
yes i am pulling a 10 foot disc with wheels and hydraulic  cylinder.When i raise my disc the 3 point has to come up and then the disc goes up. It is hard to time all of this to turn around at the end of the field. Thanks
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 4:20pm
What tractor would be helpful as well?  The D series have different valve than the say WD/45s
Still in use:
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 4:25pm
Raise the lift arms and tie them up so they can't go down. Then go disc your ground. I've done it for years. Forget the transport valve.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2015 at 8:07pm
But, this sounds like you do not have a mounted disc with wheels but simply a pull type disc attached to the draw bar.  If that's the case, the transport valve does nothing for you.  I'm assuming you have a D17 or WD45 or something with a snap coupler hitch and one hydraulic outlet since the lift arms are controlled by the same lever that controls the lifting of the implement.
Edited by DanD - 13 Jun 2015 at 8:09pm
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 8:51am
I think it sounds like a pull type with traction booster.
Life is simpler when you plow around the stump.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 9:30am
I don't think so because the rigid links on the traction booster draw bar would prevent the lift arms from going down...which is the poster's main complaint...that it takes too long for the lift arms to raise all the way up when lifting the implement.
A picture here would be worth 1000 words!!! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 9:39am
thank-you all for the responses. I have a d15 series 2 and i am trying to keep the lift arms up when i am pulling a disc. I am also using a dump trailer and when it is empty the hydraulic cylinder on the trailer extends before the 3 point goes up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 9:58am
Take a piece of rope and tie the lift arms "UP" to the back of the seats suspension frame. One lift arm will probably do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 10:04am
Beyond all that,the transport valve, when backed out,sends oil to the remote cyl first then to the lift arms.There's a pressure differential but I don't know what it is.If the valve is screwed all the way in ,it will be the same as not having one and the port with least resistance will act first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2015 at 10:26am
All the way out (counter-clockwise) sends oil to lift arms first (to utilize the Traction Booster feature) then the remote ram. Clockwise (all the way in) is for normal operation.
This page was generated in 1.531 seconds.
