How to tell if jumps out of gear
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Topic: How to tell if jumps out of gear
    Posted: 10 Apr 2010 at 6:00am
Exactly how would a person check to see if a tractor he might want to buy  jumps out of gear or not?  I'm not being a wise guy... I'd really like to know the best way.
I guess you could put a load of silage behind it and go down a hill, but is there a better, maybe easier way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 6:07am
Drive down hill at full throttle, then back the throttle all the way off without using any brake. My Wd45 popped out of 3rd the first time I cracked it open without any load behind it. Unfortunately it was on the way out of the former owners drive, after he had the check in hand.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 11:42am
Be sure to check for good breaks BEFORE attempting these tests though...
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 11:45am
Aw heck, you just need a hill to go up after going down the first one, that'll stop ya. LOL
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 11:49am
Try letting off the gas going up a hill and also do it going down a hill.
If it is really bad it will also jump out on flat ground sometimes under power and sometime when you back off power.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2010 at 1:36pm
Don't need any speed.  On my D14 just put it in third and drive it, if it goes without a load, coasts, it will just fall out of gear.  Don't really pop, just doesn't stay in gear.  Don't use third any, so it's no big deal to me.
