How to repair
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: How to repair
    Posted: 13 Jan 2011 at 8:25pm
a dent in the right front bottom corner of a B  gas tank.  The dent is about the size of a golf ball and about half as deep.    Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 8:58pm
Any real bodyman can pull it out with a dentpuller. Basically he welds a copper plated stud in the dimple,then yanks on it with a slide puller.A good guy can do it in 2-3 studs, a great guy will do it and NOT need more than a skim coat of bondo.
Neighbour did my D-14 air cleaner assembly.Don't ask HOW the dent got there !lol....
Obviously with a gas tank, it's be wise to flush out with soapy water before doing the work....
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 12:00am
watching a guy with the paintless dent removal working on a car I wonder if it ca nbe removed from inside the tank with leverage tool to work it out as another option,  the stud and slide hammer also seems to work as have seen cycle tanks repaired like that to almost perfect finish.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 1:51am
I've seen it done on motorcycle tanks with air pressure.
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 4:11am
dry ice?
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 4:25pm
Tmiller - The stud welder is the way to go.  I had three dents in CA tank.  Gave to neighbor, who is body man.  He had it repaired in about 1/2 hr.  All I had to do was give it a skim coat of bondo and paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 5:50pm
Thanks for the replies........Hadn't thought of a dent puller.........I have a friend that teaches auto body repair at the local Community College,  maybe some of his students need dent removal practice.     Tim
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 11:10pm
So................. How "did" the dent get in there?
Why is there never time to do it right the first time, but always time to go back and fix it?
