How to Remove wd45 hand clutch shaft |
Post Reply |
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 998 |
Posted: 30 Jun 2022 at 8:20pm |
I have a lot of slop in my hand clutch lever so I pulled the lever. It needs two new bushings but the shaft is badly worn as well and will need to be replaced. I know the shaft is frictional fit. I can get it to spin with a pipe wrench and a cheater bar but anyone got any ideas how to get it out?
MACK
Pull right frame, weld nut the size of your slide hammer to end of shaft, and pull it out. MACK
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1902 |
I take the shift tower off and pound it out from the inside.
http://lonsallischalmers.com
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7910 |
I had no luck driving out from inside.
dr p
Tried Mack's idea and snapped the shaft.
dr p
Ended up drilling a 7/16 hole though the shaft near the housing and VERY SLOWLY pulled it out. Took a ray Wylie Hubbard and a Tom h hall CD to get it out. Got advice on putting new one in. Think I will chill it in dry ice
SteveM C/IL
have something between it and the hammer or you'll end up swelling the end
dr p
Thanks everyone
Post Reply | |
