How to mount belly mower to G?
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Topic: How to mount belly mower to G?
    Posted: 18 May 2010 at 2:10pm
Has anyone ever done/seen a G with a belly mower?
I ask because my two G tractors came with a 5' woods belly mower, but no mounting hardware etc.... Did woods make a kit?? Any info/pics would be greatly appreciated!
Jonathan in NY
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
AC G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC G Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 3:01pm
We bought my G at my grandfathers farm sale and it had a belly mower on it. not sure who made it, but i know it mounts in the rear and there is 2 chains that hold it in the front on the frame, and the chains are where plows mount and other implements fasten.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 3:59pm
Woods shows a 42 in mounted on a G. It mounts behind the back wheels on the vertical casting. Page 6 shows the hardware.
http://www.woodsequipment.com/WorkArea/showcontent.aspx?id=11143
 Some on here have said the 59 in mower is a bit much for a G. If you never let it get ahead of you and use the granny gear you might be able to push it around.
Edited by CTuckerNWIL - 18 May 2010 at 4:01pm
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 4:20pm
Check out Tom's G with mower... link
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 5:39pm
I run a Woods G42 mower on a G and like it real well. I mow Christmas trees and a farm yard with it. I had a 59 on a G I bought. It was OK if you mowed an inch at a time, but if the grass was heavy or a little long the little G really struggled. I took it off.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 6:46pm
Anyone know what make that mower is. You don't see one driven from the crank very often.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 8:39pm
Go to Tom's home page, and you'll find his email address.  Or he might see this and post details on his mower.
