How to change a WD hand cluth |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Topic: How to change a WD hand cluthPosted: 12 Dec 2013 at 7:02pm |
I was changing a hand clutch for a customer today and thought I could take some pictures to help out others with the same problem.
STEP 1: Take out the four bolts where the frame rails bolt to the rear axle. You also need to remove battery box, hand clutch cover, disconnect the PTO shaft, traction booster linkage, hyd rams, steering post, hand clutch linkage, and brake rods. Leave the 6 bolts holding the transmission to the hand clutch housing. Also drain the oil from the tranny and h.c. housing. STEP 2: Thread 1.5 ft of 3/4" threaded rod into the bolt holes on the rear axle. Put a nut on at least one rod to make sure the rear does not roll back too far. STEP 3: Jack up the tractor under the bell housing. Remove the 6 bolts that hold the tranny to the h.c. housing. Roll the rear back away from the front. Remove the four bolts on the hand clutch and fish the hand clutch out of the housing. STEP 4: Make sure there are no hand clutch parts left in the housing. STEP 5: Put the new clutch in and roll the tractor back together. Don't forget about the gasket! STEP 6: Bolt everything back together and reconnect the linkages. Make sure the hand clutch rotates and disengages before putting too much back together. Remove the threaded rods one at a time and put the bolts back in. STEP 7: Start her up and test her out. With a little luck and skill, everything will work ![]() |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 12 Dec 2013 at 7:20pm |
Very interesting, I've never done one.Thanks for posting that.
wjohn
Posted: 12 Dec 2013 at 7:46pm |
I'm still baffled as to why we don't have a stickies/how-to subforum under the Farm Equipment forum on here. Threads like this would be easily accessible for reference - no trying to figure out the perfect keywords to use a finicky search function, or bookmarking and then having the web address change a year later, rendering your bookmark useless.
I'd nominate this thread. Thanks for taking the time to post pictures - I haven't changed a hand clutch either, and it's neat to see the components getting some air.
NickH
Posted: 12 Dec 2013 at 7:53pm |
very nice detailed post I agree that there should be a subforum for helpful posts like this
"Allis Express" Northern Utah
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 12 Dec 2013 at 8:38pm |
Thanks for posting w/pics . One of our next projects .
NDBirdman
Posted: 12 Dec 2013 at 10:17pm |
Cool. Your still basically splitting the tractor, right? Just using rods to keep it close?
B26240
Posted: 13 Dec 2013 at 6:48am |
Great post !!
Rltool
Joined: 17 Jun 2013 Location: Middleville ,MI Points: 1833 |
Posted: 13 Dec 2013 at 8:46am |
Thank you for taking the time to post this. This is a great help. Very well laid out. I 2nd the how to thread.
Ray W. |
Brian Jasper co. Ia
Posted: 16 Oct 2016 at 8:58pm |
I like the threaded rod idea. I wonder if that could work on a D17 to get the Power Director out?
9GRANDKIDS
Posted: 16 Oct 2016 at 9:18pm |
I used this process to pull my hand clutch today - rivets were sheared off both clutch plates. I had trouble splitting for a bit then realized that the PTO shaft was hung... I had the shear pin out, but the hole was warbled a bit and flared the PTO gear out into the holes in the shaft. I just pulled the 2 bolts on rear carrier and let the shaft drop enough to clear the differential. Other than that and a couple of bolts being difficult the process was easy.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4278 |
Posted: 17 Oct 2016 at 8:01am |
Good post, the two I have changed I had the engine out of the tractor. If I just needed to change the hand clutch, would definitely use this method.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 17 Oct 2016 at 9:31am |
good post looks like the heater in the shop didnt work
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 17 Oct 2016 at 10:04am |
There is a sub forum for this type of info. It's called Farm Equipment-Knowledge Based. Second forum area on the list.
