How to Adjust Brake Pedals HD9 |
BillRO
Joined: 10 Sep 2014 Location: Albertville, AL Points: 18 |
Topic: How to Adjust Brake Pedals HD9Posted: 10 Sep 2014 at 6:03pm |
Please give me Advice on how to Adjust the Brake Pedals on a HD9, Thank you for your Help
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 10 Sep 2014 at 10:41pm |
Clean the rear case under fuel tank,shoud be a cover bolted on (been a long time don't remember how many bolts or size)slide cover back.The adjuster is right there,tighten until you cannot bottom out the pedal.
gemdozer
Posted: 11 Sep 2014 at 5:10am |
Like RAY54 said remove the small cover on the stering cluch compartiment cover under the fuel tank and turn the brake adjuster clockwise until the brake pedal has 1 3/4" to 2" free travel
BillRO
Posted: 11 Sep 2014 at 5:56am |
Thank you
BillRO
Posted: 11 Sep 2014 at 5:57am |
Thank you For Confirming RAY54 and giving More DETAILS
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 11 Sep 2014 at 4:44pm |
The dry clutch tractors also have a set scew up through the bottom of the housing which touches the bottom of the brake assembly. After adjustments, you take it up tight then back off I think one and a half turns. Its purpose is to prevent the top linings dragging on the drum when the pedals are back. Many of those have been thrown away leaving a hole for dust an mud to get into the housing
BillRO
Posted: 18 Sep 2014 at 5:54pm |
Thank you Mac
BillRO
Posted: 18 Sep 2014 at 5:55pm |
Thank you
