How screwed am I on this Allis WD45 block?
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: How screwed am I on this Allis WD45 block?
    Posted: 18 Nov 2024 at 1:26pm
What are the chances that both sleeve rings have failed on sleeve 3 & 4 and the block is not cracked?
Edited by twinson - 18 Nov 2024 at 1:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 6:10pm
What are the odds that four Orings have failed on TWO sleeves exactly in the center of the block right where the blocks are known to crack ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 7:49pm
Yeah, that's what I was thinking.  This block is junk then correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 8:57pm
Kinda looks like the one cylinder has been leaking for awhile according to the rust around the sleeve at the block. Did you pressure test it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 9:23pm
Probably junk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 9:28pm
Pressured up to 15psi and started dripping.  Lost pressure within 5 minutes.
Edited by twinson - 18 Nov 2024 at 9:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2024 at 6:59am
It may be junk but the only way to know is to tear it apart. A few hours of work and you will know.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2024 at 7:07am
I have a bare block with no cracks between the cylinders if you are interested.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2024 at 8:03am
has anyone ever tried any BLOCK SEALER in this application... Either something like BARS that you pour into the antifreeze and run it... or a liquid you pour in around the liners and let it harden around the base ? ( when the block is empty and head is off )..
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 10:13am
i would like to see bad the pitting is right around the orings  my series 4 engine  block my might be to bad to keep mine sealed  sealed up , dont know if any thing can be done down in the bottom of the counter bores
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 8:42pm
twinson,
 BTDT.
It sounds like your pressure test found the issue. Were you getting coolant in the oil? Gray foamy stuff under the valve cover?
I had to replace the block in my 45 project. Just lucked out and had a rebuild-able block sitting in the garage. It was not a cheap date, but nothing is now days. You might find a running engine??
Keep us informed.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 8:44pm
Gray foam yes.  Looking for a new block that wouldn't too far of a drive.
