How much to remove off hollow shafts
KansRustbuzzard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KansRustbuzzard Quote  Post ReplyReply Direct Link To This Post Topic: How much to remove off hollow shafts
    Posted: 12 Jul 2022 at 4:23pm
When polishing out the galling, how much can I remove  without getting in trouble? The inside  shaft polished off real clean while chucked in the lathe but the short shaft is a lot worse right under the gear as in picture.  Am I going to mess up by taking too much out of the inside? Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2022 at 7:40pm
They run pretty close together. That is why they occasionally seize when bearings get worn a bit. I have opened them up as much as .010" (removing .005" x two) without any regrets. Too loose and they can't ever do what they did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KansRustbuzzard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2022 at 11:39am
Thank you for that information, I am going to take some more off, no reason to do this twice!
