How much oil?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: How much oil?
    Posted: 03 Oct 2011 at 6:28pm
How much oil does it take for a WD-45 gas? I put in 6qts pulled the dip stick-no oil. What the @#$%$#. It takes alot less if you put the drain plug in. I guess I kinda flushed it with new oil. It's tough going through life dumb and ugly by I try.  Best thing is I don't even get mad anymore.  Mike
wdforty5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wdforty5 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 6:38pm
I ended up puttin 7 qts with filter to get my oil level where it should be on my wd45.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 7:38pm
The last time I pulled that trick was on the L175 Kubota (at least its orange) that I use as a lawnmower. Boy did I feel dumb.
Gotta laugh about it now.
Robert
Edited by Orange Tractors - 03 Oct 2011 at 7:40pm
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 7:42pm
At least you checked. Wonder how many folks have poured in the right amount and run it without checking the dipstick.
