how much hp from 226? |
JM
Joined: 12 Sep 2009 Location: United States Points: 379 |
Topic: how much hp from 226?Posted: 13 Dec 2013 at 9:13pm |
How much can you get with 226 ci. with the best carb, cam, compression,D17 spring, flow etc. ? thanks
allisanddodge
Joined: 27 Nov 2013 Location: Half Way, Mo. Points: 24 |
Posted: 13 Dec 2013 at 9:55pm |
If you can find m&w pistons for a 201 will bring up comp. quite a bit. Assuming rpm. that most pulls allow, around 18-1900, around 60 is about the best I've got.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 14 Dec 2013 at 4:13am |
Wasn't a 175 gas (226) rated at 60 some HP? So that would be top of the tractor series.
The Combine and Power units were rated higher but that was Flywheel HP
Charlie
Posted: 14 Dec 2013 at 6:52am |
The model 175 gas tractor was rated at 60 HP at the PTO and 67 HP at the flywheel, both at 1800 RPM loaded. I'd guess with a well tuned D-19 style carb, that stock engine could see maybe 73-75 flywheel HP at 1800 RPM, but at 2000 loaded RPM for sure. More compression and good racing gas will just keep adding to those HP numbers.
JM
Posted: 14 Dec 2013 at 10:46am |
Thanks for your replies. Now lets go the other way, lets say its only gonna turn 1500-1600 rpm, how can you make this engine lug--torque? I am guessing cam and its timing would be a big part of that, how about compression? I always heard high compression is great for hp, but not torque. I have also heard high compression with good fuel and retard the timing will bring torque. I am trying to figure out if there is any way to get enough power to run 38 inch wheels on my wc in the 4000lb. class. I have seen WDs with 45 crank and 4.125 flat tops struggle to do it. I know wd is geared lower than wc, so I wonder if I can do it with out building a "bigger enginge".
Posted: 15 Dec 2013 at 7:08am |
Camshaft timing advance would help with "lug". These flywheel HP specs are from a standard D-17 gasoline @ 1400 rpm.....52.0 HP @ 1300 rpm......48.2 HP @ 1200 rpm......44.2 HP @ 1100 rpm......40.2 HP @ 1000 rpm........35.7 HP @ 900 rpm........31.4 HP @ 800 rpm...............peak torque was at 1100 rpm with 211 ft lbs.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5198 |
Posted: 15 Dec 2013 at 8:48am |
Compression will help with torque.
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 26 Dec 2013 at 3:20pm |
Would a heavery flywheel help on lugging down? |
Posted: 26 Dec 2013 at 6:35pm |
Heavier flywheel helps somewhat delay the "stalling" of the engne as the load increases. Doesn't make any more HP, but helps in some situations and surely never hurts.
wfmurray
Posted: 27 Dec 2013 at 4:47pm |
Has anyone ever put a gas head on some thing like a 226 diesel block ? Just a lame idea.It would have higher compression and have stronger parts in all the bottom end.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7630 |
Posted: 30 Dec 2013 at 8:32pm |
No such thing as a 226 diesel block. |
