How much boost |
Ronnie
Joined: 23 Mar 2014 Location: New Brighton Points: 557 |
Topic: How much boostPosted: 04 Aug 2016 at 6:28am |
Will a stock 301 out of a 8010 take.
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 04 Aug 2016 at 7:45am |
Dont know about stock, but 8 years ago the McKimm 180 twin turboed "Power Maxx" was leaving the line under 80 lbs of pressure.
AaronSEIA |
bsallis180
Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
Posted: 04 Aug 2016 at 8:21am |
it will take as much as it can till it breaks... maybe 30psi right way put fire rings in the sleeves and forget about it
Ronnie
Posted: 04 Aug 2016 at 11:06am |
I'm making 40 pounds.
I think I will open the waste gate and keep her around 25 |
200 allis
Joined: 11 Mar 2014 Location: new jersey Points: 203 |
Posted: 04 Aug 2016 at 12:12pm |
I have a 200 makes 60 psi boost and isn't fire ringed and a friend of mine is running a 190 with 80 pounds with out fire rings
Ronnie
Posted: 04 Aug 2016 at 1:18pm |
200 allis are u runing factory head bolts and torque speck
200 allis
Posted: 04 Aug 2016 at 4:10pm |
Stock head bolts over torqued a Lil. Left rocker arm assembly off and torque with all short bolts. Then put rocker arm assembly back on and torque it down. Plugged block heater in over night and retorqued.
O.P.S. Heads
Posted: 04 Aug 2016 at 6:50pm |
The boost is a factor but not the only factor. How much power you develop is a much bigger deal. You can make 200 HP with 60 lbs. of boost or you can make 800 HP with 50 lbs. All depends on the setup. I would be certain that your connecting rods are hardened first. the softer OEM rods will bend before the head gasket blows if they are not heat treated.
I think a better way to describe performance is to give the weight of the tractor and in what gear you can spin it out - finish the run in. That is a more accurate way to describe how good the engine is and the stress that is applied to it. Edited by O.P.S. Heads - 04 Aug 2016 at 8:45pm |
Ronnie
Posted: 05 Aug 2016 at 7:24am |
200 allis do u have hardens rods in ur engine and what weight class do u run.
200 allis
Posted: 05 Aug 2016 at 9:34am |
My rods are hardened but the 7000 series rods were harder then 3# series. I have been running 7500 and 8500
Posted: 05 Aug 2016 at 11:53am |
On the 426 small pin rods, if they said JAPAN on them, there were better than newer generation rods.
Ronnie
Posted: 05 Aug 2016 at 12:49pm |
I think I will just back my boost down some so i dont break any thing.
So what would it cost to get rods hardend |
200 allis
Posted: 05 Aug 2016 at 4:44pm |
Max Simpson did my rods but don't think he is doing it any more. What timing u running makes big difference.
Ronnie
Posted: 05 Aug 2016 at 4:48pm |
Just under stock timing for this moment
