How long can primer sit before paint?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: How long can primer sit before paint?
    Posted: 19 Feb 2025 at 7:19am
My reason for asking I’m starting work on the doors for my project truck. Once the body work is done I’ll move on to other parts. It may be a few months before they get paint.
What to prime with and how long can it sit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 7:45am
At least 6 months.outside, in snow... according to my old Willys Pickup.
I'd use an 'acid etch ' primer, maybe epoxy, or 'high build'.
You'll have to sand  it down and reprime just before painting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:09am
primer will seal up the steel , filler , etc and protect everything from rust, damage while in storage..... as Jay said, the primer should be lightly sanded when you get ready to apply the finish coat ..... etching primer is a great idea as it STICKS to the metal really good.. A flash coat just prior to the final paint might be a good idea, as jay said..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:14am
I don’t mind to spray an extra coat I just don’t want to have to take every part down to bare metal again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 9:10am
nah... primer can set forever on a car... just got to sand a little to get any oxide off and then a fresh thin coat on top............ replacement fenders / doors come primered ( from China) and can set for months before resell..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 9:34am
As steve Noted, light sand, even as light as 1000gr, just to knock off Slick or Oxidation.  Normal Limit is within 12 hours to not require sanding.
Edited by DMiller - 19 Feb 2025 at 9:35am
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 10:01am
If it has sealer either under it or in it it can set. otherwise it need to be sealed within 12 hours or before it gets wet.  buildable primer dosent seal and the metal undernieth will rust . it will come out later after you paint and it bubbles up.
